redfishsc
I have an ongoing battle with my Delta Midi-lathe.
I just cannot seem to get the thing to run truly round. My problem tends to be worse at the tailstock-- I can feel more eccentric turning at the tailstock end than at the headstock end.
I have checked everything I can imagine---- clean MT2's, straight mandrel, good live center. I also use a "rotating jacobs chuck" instead of the live center often times, but the problem doesn't change by switching to the live center. The mandrel still turns out of round, especially toward the tailstock.
Nothing is overtightened. The headstock bearing is new as is the headstock spindle.
I have access to one of those dial indicators that checks the runout of machinery. How do I use it to check the runout on the lathe? My typcial setup is the Beall Collet holding the mandrel and either a live center or the rotating jacobs holding the end.
Lastly, my tailstock has a bit of slop in it- it wiggles more than I believe it should. It seems to have a few degrees of slop side-to-side, meaning that it can "point" to the right or left of the center of the headstock. How can I solve this?
Thanks for those helping me solve this 6-month problem. This is the LAST DELTA lathe I will ever buy. It barely had 20 pens worth of time on it when I bought it used, I should not be having these kinds of problems.
