workinforwood
I was wondering if anyone can accurately measure the inside diameter of the 2 tubes used in the JR Statesman II, which I think is the same as the Gent II. I'm ordering some aluminum and would like to have them drill it out to that diameter so that I don't even need to use the tubes. My calipers are plastic, unreliable and can't honestly say I know how to read them anyhow. I use them to measure and match only, so if one piece says 49, the other needs to be 49, hahahha. Then I also say a prayer.
Thank you guys so much. If two different skilled people can take the same measurements, all the better.
Also...is there a specific grade of aluminum I should be asking for?
