Rockytime
I should know better than to trust bushings. I should also measure to verify. Turns out the bushings are .002 larger than the hardware. OK, so thar's on me. I'll give the pen away. I was going to anyway. Next is the matter of the copper tip. No amount of pressure will press the tip completely in. I think the plating may probably be a little too thick. Not looking for a solution. The lesson I learned is to be a bit more judicious and use my calipers.
