brownsfn2
I need a little advice. I ordered a piece of Mexican Agate from Craft supplies and the piece I got had a white blotch in it that went through to the drilled hole when I drilled the blank. They were very kind and replaced it right away.
The new piece I got showed a small white blotch on the outside and when I drilled the blank I could see it was bigger on the inside.
Does anyone know if this is a common problem with this material? I have turned 2 in the past and did not have any white blotches or specs.
I am going to call Craft Supplies but with two blanks in a row having the same issue I am worried.
Anyone else have this issue?
