rlh
I am curious to know how the grain can be matched on a Perfect Fit pen. The upper barrel tube is 2-1/4" long and the blank starts out the same length. However once you finish turning the blanks down the directions tell you to part off the wood leaving 1-7/8" of wood. By doing this you have eliminated 1/4" of wood at the center joint. On a blank with a figured grain that 1/4" will make a big difference in grain match. I am about to turn my first Perfect Fit and am trying to get things right before starting. Your help will be greatly apprecisted. Thanks.
