Tiger
There are plenty of posts on these forums about the lack of concentricity on bought bushings. I have a metal lathe and would like to make an accurate set of bushings for pens. I would have turned to outside diameter and then drilled a tight fitting hole to run on the mandrel, I gather from some posts that that may not result in the most accurate bushing so would it be better to drill the hole first, chuck some sort of mandrel and then turn to the required outside diameter. What is the recommended method for ensuring accurate bushings?
