Making an 8mm mandrel saver?
mikeschn
Lake Orion, MI
So I've got some pen kits that require a B mandrel (8mm)
I don't think anyone makes an 8mm mandrel saver. Can I make one myself? How would I go about that?
Mike...
chartle
Pgh, PA
Mike...
I've seen live centers with various inserts. If there isn't a correct insert I guess you could turn something to fit.
its_virgil
Wichita Falls, TX, USA.
Drill the hole on the standard mandrel saver for the B mandrel. I made the through hole on mine larger and it works just fine,
Do a good turn daily!
Don
PS: Bushing for the kits you want to make are probably available to fit a 7mm mandrel.
Mike...
KenV
Juneau, Alaska.
Got a metal lathe and know how to make it "sing"?
On the other hand, the additional diameter of the B mandrel makes it a lot stiffer, and reduces deflection under compression a lot. If you use a collet Chuck to mount the mandrel and keep it as short as practical, it will be even more stiff.
I have been looking for a long time and there is not the demand to get minimum order quantities.
