Majestic Crystal Removal
flyitfast
San Antonio, TX 78247
I need to change the crystal in the clip for a Majestic. Has anyone done this and what is the "safest" way to get the clear crystal out?
I want to change the crystal that comes with the kit and put one of another color in to match the blank.
I hate to pry too much on it for fear of scratching the plating.
Thanks to whoever has the solution.
Gordon
BSea
Little Rock, Arkansas
I just take a small knife & pry at the edge of the crystal. It just pops right out. I've only done 2, but both came out easily. It has a slight crunching sound. I'm guessing it's the glue holding the crystal.
flyitfast
Thanks Bob,
I'll give it another try. They really glued this one in without leaving much room to get a knife blade in. Just don't want to scratch the metal...
Appreciate the response.
gordon
76winger
Lebanon Indiana
I thought I saw a link once where someone applied a small amount of heat to ease the removal, but I don't recall the details. Maybe use a hair-dryer to warm it up, then try prying on it gently...?
flyitfast
Majestic crystal - Case Closed
Thanks Bob and Dave. That heat gun I bought at HF, and forgot about, did the trick! Low heat for a couple of seconds was all it took. Popped right out with the knife point. (now I have to find it!):mad-tongue:
CASE CLOSED.
Appreciate
gordon
