majectic jr. vs emporer jr.
glycerine
Fayetteville, NC
Are the tubes for the majestic jr. and emporer jr. about the same length and diameter?
I ask because I'd like to put a laser cut star spangled kit on an emporer jr. and I have not seen them, but have seen them for the majestic jr.
johnnycnc
columbus, IN, USA.
I just measured sets of each for you, and here is what I find;
The Jr Emperor upper (large) tube is about 1mm shorter than that of the Jr Majestic.
other than that, they are the same.
You would lose appx .5mm of blue on each end of the upper,if you get it perfectly centered lengthwise.
I have this blank on a Jr Majestic, and there is plenty extra blue on each end.
I don't see an interchange problem.
glycerine
Fayetteville, NC
Ok, thanks. I swear I replied earlier and now my post isn't showing up... Anyway, thanks for checking. I imagine if I have a set of tubes for a jr. majestic, I could probably just use that with the jr. emporer kit as well. But with just a mm difference, like you said, it wouldn't matter.
