Machining Corian
RPM
Atlanta, GA, USA.
I have drilled, turned, routed and sawed corian. I am interested in using some very thin stock. Anybody tried or know if it can be plained? Can't really think of any reason it couldn't, but I don't want to experiment with my plainer knives.
Thanks,
Richard
ed4copies
Local Chapter Manager
Racine, WI, USA.
Richard,
I have never planed corian.
But, isn't it the same as cutting it with a skew??
Should work if you take thin passes.IMO
its_virgil
Wichita Falls, TX, USA.
Contact Barry Gross at http://www.bgartforms.com . Barry will know if it can be done and how is the best way to get it done.
Do a good turn daily!
Don
Originally posted by RPM
<br />I have drilled, turned, routed and sawed corian. I am interested in using some very thin stock. Anybody tried or know if it can be plained? Can't really think of any reason it couldn't, but I don't want to experiment with my plainer knives.
Thanks,
Richard
terrymiller
Germany
Richard I have planed some down after resawing it for some Christmas ornaments. I worked about the same as wood does you just have to take a little thinner cuts. If you take to deep of cuts it will heat up and possible shatter. DAMHIKT
