Loose Upper Barrel
thostorey
Qualicum Beach, British Columbia, Canada.
I turned and assembled a slimline and all went without a hitch until I slid the upper barrel over the transmission. When I twisted the barrel to extend the ballpoint, I found the barrel to be loose and would not properly grip the transmission. I ended up having to apply a pinhead drop of solder to a couple of spots around the diameter of the tx tube, then filing the solder down a bit until the barrel would slide on with a tight fit. [8D]
This particular kit is one of the $1.49 efforts sold by AS. Anyone else experience this? or was this a 'one of' problem.
G
Guest
Guest
Any chance you reamed the inside of the barrel with the pen mill?
Kyle
Royalton, VT, USA.
I just went through this with THREE pens, including an antler pen, using PSI kits. I am fairly certain that the problem is entirely mine, induced by sloppy use of the reamer or perhaps having a somewhat misaligned reamer in my drill press. Sometime the flat side of the bit get chucked a little off in the drill press--I should of caught this when I used it--but maybe not. At any rate, the inside of my tubes are chewed up, and I think I deserve all of the credit.
I'm being more careful now!
Kyle
Kyle
Royalton, VT, USA.
P.S. Nice tip on the use of solder to remedy the problem. I was thinking of trying the same thing with thick CA, and was dreading the potential results.
Kyle
G
Guest
Guest
Two thoughts
one DONT try ca glue!
two is the fit sloppy enough for another tube to fit inside the over sized one?
Kyle
Royalton, VT, USA.
I agree about the CA thing, but I don't think I'd ever get another tube inside of mine. Solder still seems like the best bet (other than the wood stove).
Fred in NC
LANDIS, NC, USA.
Reamer in a drill press? Not in my life!
I make wood handles about 1" dia. for anything that goes inside the tube. Drills chew up my tubes! Keeping the inside of the tube clean while gluing is a good start.
G
Guest
Guest
Originally posted by Kyle
<br />I just went through this with THREE pens, including an antler pen, using PSI kits. I am fairly certain that the problem is entirely mine, induced by sloppy use of the reamer or perhaps having a somewhat misaligned reamer in my drill press. Sometime the flat side of the bit get chucked a little off in the drill press--I should of caught this when I used it--but maybe not. At any rate, the inside of my tubes are chewed up, and I think I deserve all of the credit.
You did mean Pen Mill right?
Kyle
