Looking for replacement springs for Sierra
patmurris
Nice, French Riviera
Hi all!
I'm looking for replacement springs for some Sierra kits i have which have a very weak spring, allowing the refill to wiggle inside and make a cheap 'clic clic' noise - spring #1 below:
I would need either tapered or not tapered springs like the others pictured here.
Any supplier you know of?
Thanks :wink:
patmurris
Wood and whimsie sell them. What I do if the spring is a little loose is just stretch the spring a bit and then there is no play.
I emailed them to make sure the ones they sell are better then the ones i want to replace (there is no picture on the web site)... As for stretching the spring, i tried, but although it's a little better it is not enough to my taste.
