Long Click Mechanism Length
Mapster
Orlando, Florida
Has anyone tried to shorten the click mechanism of the long click pen? It appears as though the lower inch or so is completely unnecessary. Thanks for the input!
BSea
Little Rock, Arkansas
I agree the lower half seems unnecessary, other than to make sure the refill is engaged with the clicker. there is a lot of travel in the long clicker. And no, I've never successfully disassembled a long clicker. I tried once, but it destroyed the click mechanism.
chrisk
Brussels, Belgium
The Longclick length is 105mm (4,134"). I do shorten (with a carbide pen mill) this barrel's pen after finishing mainly for converting the Long click ballpoint pen to a mechanical pencil, using a Schmidt DSM 2007 mechanism. The minimum shortening is 1,5 to 2 mm (0.06 to 0.08") but 3mm (0,118") works fine for the DSM 2007. One can also use this shortened barrel as a ballpoint pen but I generally avoid if it's shortened more than 0.06" for the Parker refill extends too far and, while workable, it's unsightly.
Hope this helps.
