Manny
OK this is what I am doing with these pens when I need to take them apart. Seems to work for me.
I take an extra nib and cut it down from the narrowest point to where the threads are
I then insert into the narrow end an 8mm set screw socket. You could use a 8mm bolt as well.
Take the nib off the pen you want to disassemble
Screw on the cut cap with the 8mm set screw socket
Insert the appropriate socket wrench and turn counter clockwise.
(The 8mm set screw socket is screwed in the opposite direction of the pressure fitting you want to remove.) So it turns right out.
Just use some pliers to unscrew the pressure fitting.
Again you can use a screw with pliers to the same effect. I think a hex wrench with the 8mm set socket screw welded on would be a great tool.
Manny
Manny
