Manny
Any good way to take these bad boys apart without destroying the click mechanism
Manny
Manny
I took the other end of one, it had a plating defect I didn't see until AFTER I pressed it together.
Found that a ball end hex key worked great holding the pen in my hand and wacking the key with a deadblow hammer. A couple dozen strikes and the nib came off in my hand.
I would think the proper size hex key might give you enough support on the clicker end to not ruin it.
This is when a set of transfer punches comes in handy. You can get a decent 28pc set for $10 - $15. The will normally have punches from 3/32 - 1/2" by 64ths and about 5" long. This will give you a punch pretty much the size of any tube you need to get a mechanism out of. That along with a dead blow hammer or a brass hammer will allow you to disassemble just about anything.
