woodscavenger
I use some picture frame wire for burning lines in my pens. I wanted a smaller line so I unravelled another section of wire (it was 4-5 wires per strand) and when I used a single wire it heated up and broke without leaving a burned line. [}] Are there other trick to getting bigger/smaller burned lines?
You can see some of the lines in the pic below.
Image Insert:
Image Insert:
