tool-man
I am assembling my first Liberty pen kit. The first pic below shows my barrel with the front section and clip assembly pressed into place. And beside the barrel is the twist mechanism ready to be installed.
Then I screw the twist mechanism into place. And when I have it very finger tight, the mechanism protrudes about 12 mm as shown below.
Then when I press on the Finial cap it does not go completely down against the clip. I sense a pretty firm stop, and there is about a 1 mm gap between the bottom edge of the finial finial and the clip assembly. I am pretty sure the finial will not seat further. Looking inside I see what appears to be a stop groove inside the finial and my measurements seem to confirm I am up against that stop.
Is 12 mm the correct distance for the twist mechanism to stick out? I think either (a) the twist mechanism is not fully screwed into place, or (b) I am not pushing the finial all the way on. Or ??? I hope someone with Liberty kit experience can offer some advice. Thanks.
