Leather for pen blanks?
Cavediver
Tucker, Ga
Some of the leather pens shown here have really piqued my interest. Since I've got a leather store nearby (Tandy Leather), it's almost mandatory that I give it a try :biggrin:
Tandy has a bunch of different remnant bags for sale. Are there particular leather types I need to buy or avoid? I'm guessing the stuff that's heavily oiled wouldn't be a good idea, but beyond that I haven't a clue. Should I be looking at the heavy duty stuff (tool belt / holsters), or will suede and other soft leathers do the trick?
Thanks!
wyone
I have only made a couple leather pens, but plan on making some more in the next few weeks. I like all different thicknesses and types and colors of leather. Each gives a different effect. The messiest part is the actual glue up. LOL
This is one of my favorite pens I have ever made.
Cavediver
Tucker, Ga
Thanks Mitch. That's actually the pen that kick-started my research :)
Did you have any troubles with particular types of leather, or did it all work regardless of the grain / weight / etc.?
asyler
Local Chapter Leader
bryant , ar
i've made several leather pens, i got a harbor freight die kit, punched out disks, dampened them and made a gorilla gule 'sausage' wrapped in wax paper,lightly clamped so as not to distort, let dry, drill leaving the wax paper in place , add tube and gently turn,,.( i used 80 grit sand paper) finished off with kiwi shoe polish,, i used random thickness and color leather scraps
good luck
Sataro
Mexia, TX
To cut out my leather for pens, I use a .50 cal shell. I cut off the primer end. Then I ground the cut end down to about a 45 degree angle. Place the neck end into my drill press. It will cut out nice disc size leather rings for making pens.
Cavediver
Tucker, Ga
Thanks Ben! PM on the way!
Great idea Billy. I was planning something similar for punching the interior hole using a sharpened length of pen-tube brass, but didn't have a good idea about cutting the outside . I don't have a .50 shell, but there's more than a few of gun or surplus stores in my area that should have one.
oregoncarver
I use a short piece of brass pipe ground sharp on one end to punch out the sections. I drill a 7/8 inch hole in a 2x4 so it is partly exposed and glue up the leather by stacking it and adding expoxy each piece. Top with wax paper and clamp. Drill and then cut away the waste wood. I also like tk mix leather and wood together.
Huskysibe
Burleson, TX
Approx how many pieces of leather does it take to make your blank? I suppose I could enlarge the picture in the 2nd post and count the rings. I assume the varying thickness of leather is a deciding factor also.
