jskeen
Somebody said they wanted to see this, so here's the widget in question, and a few of the products. It's a standard 5/8" id pipe nipple, about a buck at the hw store. the little chrome fitting I had in the misc plumbing drawer of my rollaway, and the bolt and brass nut were in the misc bolt drawer (I'm sorta strange that way) Anyway, I happened to have a tap on hand for the threads on the bolt, so I tapped some threads into the neck of the fitting, so that the bolt screws in. I originally planned to use that to force the leather washers out, but it was way too much trouble. It does center the stem on the pipe pretty well, but it's not necessary. you could do the same with a bolt that was a nice snug fit, or a stud and a nut inside the fitting, as long as it was less that 5/8" so the pipe will fit over it. I just put the pipe between centers on my lathe and sharpened one end with a file. Anyway, I mount the widget in the drill press at low speed, and punch away. It cuts about 10 washers before it gets tight and starts burning the outside edges from friction. Not a life threatening problem, but I usually cut about 10 and then punch them out. Depending on the leather you're using of course.
I try to keep at least 4 of the cigar's on hand, cause I can never guess which version somebody is going to want, and I don't seem to have much luck saying "let me show you this" and switching the tops. Thought at first it would sell as a gimick "look, you get 4 different pens for the price of two. Nope. Don't know why, but with 4 of them sitting there, it seems like if somebody stops to look at them, they only pick up one, and it's always a different one for different people. Go Figure!
Anyway, which one do YOU like best?
