Gary,
I have used 6.7 and 6.8 mm in the past, and had problems due to starved glue lines.
Also, if you just using the tube to hold parts into some other medium that wood, why not drill to fit directly instead. Have done that as well.
I did an aluminum pen in longwood style, there I used the 6.8 to tight slipfit the tubes, because you need them in order for it to function, because aluminum did not have enough holding power to keep the tranny from slipping when extending and retracting. However, it you are using steel, there is enough holding power to grasp the tranny. You will still need to open the bottom area to 6.8mm to house the brass tubes that are needed to function with this kit
Jerry
