Lathe Question
jleiwig
Monroe, Ohio, USA.
I'm trying to sell my Jet 1220 lathe to purchase a metal lathe. That being said I have a couple questions.
I checked out the 7x10 toy at Harbor Freight yesterday, and I don't think I want one that teensy. They list a 8x12 for $549.99 and the 9x20 for 699.99. I'm hoping I can use one of these 20% off coupons that I've got from a bunch of different magazines which would make the 8x12 439 plus tax and the 9x20 559 plus tax. It says in stock merchandise only, but I hope the manager will work with me on it.
Given those two models I assume most everyone would chose the 9x20? Any drawbacks to the bigger lathe?
I'm obviously going to put a QCTP on the lathe and some of the other modifications I've seen on other sites, but anything else anyone would recommend?
johnnycnc
columbus, IN, USA.
Justin, you can always make small parts on a big lathe.
Out of the choices you list..9X20 all the way.
you will need the length; by the time you mount a longer workpiece up, get a big old drill chuck in the tailstock ,and a longer drill sticking out of said drill chuck,
your length real estate vanishes pretty darn quickly!
Those are not bad little machines all in all.
QCTP is a no brainer, for sure. I would hurt someone if they took mine.
Be prepared to make some mods, do some tuning and tweaking and a whole lot
of learning.
Metal lathes are great if you can learn to use them correctly,
just be prepared for a learning curve.
And have a few hundred extra for tooling!
Another option, said to be pretty nice quality, out of the box, is the micro mark 7X14.
Have fun!
j.d.sackett
las vegas
i have to call a bs on this machine. the specs cant be correct. for one thing, i have never seen an asian 9x20 with a power cross slide. i havent seen everything, but dont think it does. also, they say bed width is 9". my 12" is only 7 1/4". weighs 175 to 200 pounds???? thats light even for a 9x20. should go 250 or so. weight is your friend with metal turning tools. a 9x lathe isnt a bad machine, but will need some tuning, but dont buy this one. imho its misrepresented. regards, j.d.
workinforwood
Eaton Rapids, Michigan, USA.
Yea, I think that guy is confused on his weight is all. He isn't a dealer of equipment, he bought this machine, didn't use it and now is getting rid of it. It sure looks like it has powerfeed. I don't know that the cross slide is also power fed or not, but I know the 12x30 that I own can have that option. There's certainly lots of lathes out there available, and I am not any sort of metal lathe expert. I still say buy the biggest machine you can afford. Don't worry about tooling, spend all your money on a machine then save up for some tooling. Ebay and Enco are good. Look for free shipping. Free shipping is not uncommon righ now on big equipment.
jleiwig
Monroe, Ohio, USA.
I have lathe experience, both manual and cnc, but the last lathe I worked on would take up my whole shop and then some of my house!
That being said there is an old Logan lathe local on Craigslist for $350 that I may go look at. If I bought that one, I'd have plenty left over for tooling, but I'm worried it would turn into another project. Although any lathe will be a project I guess. Decisions decisions....
