Razorburne
I've read several posts that seem to indicate some of you do no actual turning with tools when shaping inlay kits, but rather only use sandpaper. I'm thinking of doing my first inlay kit at some point - I currently only have Easy Wood Tools carbide tools in my possession and I'm assuming that although sharp, the scraping action may not be the best approach for an inlay kit. I'm assuming it might cause a catch and grab on a piece if it happens to be protruding etc.
So I figured if sanding only is a good option, that maybe that's how I should go about it.
Question to those with experience doing this: do I just do the sanding as usual, first rotationally with the lathe on, and then straight up and down the length of the blank with the lathe off to remove circular scratch pattern? Work my way up the grits and finish?
Any pointers or comments for me ?
