Laminating PVC???
wayneis
Okemos, Michigan, USA.
It depends on what you are laminating. If you are talking about maybe gluing on a piece to turn into a centerband or when gluing multiple pieces of wood slices to make a blank I have. So far I have been lucky and have not had any problems. I would not use it when gluing tubes in though, just so that I get as strong a bond as possable.
Wayne
daledut
Swanton, Ohio, USA.
What I normally do when laminating PVC is put CA on one surface and spray the other surface with accellerator then press togehter for an instant bond.
pen-turners
Honolulu, HI, USA.
Got it to work. Used Dale's method but just pressed the 2 pieces together and then sprayed the outside with accelerator to hold them until drying. Worked like a champ.
Chris
