hotwire55
I posted a sierra today and I wouldn't consider trying to sell the pen, because the fit between the blank and the nib appears to have a gap. It's like the blank has a crown across the top, being higher near the tube, causing a small visible gap when the components are pressed together. I am using a rod in my drill press, fitting the blank over the rod and a very flat wood surface to lay 900 grit sandpaper on, then I lower the blank and rotate it by hand to flatten both ends of the blank. I realize this is a problem I will have to solve, before I can sell my Pens. Any suggestions for this newbie? Thanks in advance. -Bobby-
