KOJENT KIT
avbill
San Bruno, CA, USA.
I have several questions about the Kojernt Pen kit.
Has anybody seen this kit?
Who supplies this Kit?
It uses the same drills as Jr Gentlemen II. are the bushings the same?
Thanks Bill
corgicoupe
Smoke Rise, GA
Careful...the instructions don't make it clear that the barrel bushings are different sizes. The schematic does, but the text does not say that the back end is about 0.030" smaller than the nib end. The decorative rings for the nib end are larger diameter.
Dan Masshardt
Mechanicsburg, PA
Yes. Same as the Jr series and Atrax.
corgicoupe
Smoke Rise, GA
True. But the Kojent instruction sheet has a drawing that implies the decorative rings are identical (same letter designation) but they are not; and that the fittings are different, but they are identical. If you put the rings on the wrong ends of the barrel, you will probably feel a slight mismatch. The instructor for my first pen was unaware of this size difference, and the text instructions make not mention of it.
