Keychain Bushings
Toni
Phenix City, Alabama
I have the secret compartment keychain kits and would like to make them. In the past I did not use bushings (because I did not even know what bushings were). I am curious if there is a pen kit that uses the bushings for this keychain kit?
Thank you for any help you are able to offer:biggrin:
seamus7227
Wichita Falls, TX
If there is, i would like to know too! I went off and started using the slimline bushings and realized they weren't accurate, wew, thank goodness it was before it was too late!!!
nava1uni
San Francisco, CA, USA.
There are actually bushings for secret compartments. There are three sizes depending on who you got them from. PSI uses one for their secret compartment that is 10mm,, Woodcraft's toothpick/secret compartment is 11 mm and their pill holder and CSUSA's is a 9/16" The differences are determined by the size of the tube.
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Three Bushing Set
There is a bushing set for these....work for PSI and Rizheng (10mm) key chains. Oddly enough it is a 3 bushing set. Don't know what the center bushing is for.
