Keeping the Sierra from untwisting
GouletPens
Ashland, VA
I've had a couple of customers complain to me about the way the Sierra twist pen comes untwisted when trying to retract the refill. I'm trying to figure out the best way to keep the threads tightly locked, while still allowing them to untwist and change the refill when necessary. I'm thinking some kind of rubber/silicone/something to put on the threads so they won't be so likely to come undone when in normal use. Has anyone else had this problem and what was your solution?:confused:
GouletPens
Ashland, VA
Are these things that would last after the nib is removed and then again replaced? I'm trying to think about the customer down the road, that the Sierra will stay together without them having to do anything additional to the pen like reapplying the threadlock or using tools to ratchet it down....ideally something that I could do that would still allow the pen to be unscrewed many many times as desired, but not unintentionally like in normal twisting for retracting and exposing the refill.:eek:
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
No, but as infrequently as a Parker refill has to be replaced, is it really asking too much for a consumer to tighten the transmission?
bitshird
Adamsville, TN, USA.
Brian, I've been doing mine as Lou suggested, But I remember my x's uncle was an Optician, his method for keeping screws from coming out of the temple pieces on eyeglasses was to just a tiny dab of school paste, My fear of telling a customer to use a pair of pliers to loosen or tighten the transmission to change the refill is this.
If they were clumsy enough to not be able to tell they were turning the body so much as to loosen the transmission from the nib, Imagine what they could do with a a pair of vise grips, I only use a very small pair of channel lock pliers about 3 inches long.
You know they aren't going to spend the money for a tool that is adequate for a delicate job. Then your going to get to replace a transmission which aren't available with out the kit.
GouletPens
Ashland, VA
Keeping in mind, too, that the customer is not going to be "assembling" their pen back when they change their refills. They are just going to be screwing it together, with only the exterior, finished parts exposed, unlike us when we assemble them. I'll try the school paste.
To answer the question about the ink replacement, they actually replace it often enough to be an issue. I replace my refills with gel rollerballs which write nicely but run out sooner. Especially when someone loves their pen and they begin to use it exclusively, it runs out after a couple of months, if not sooner. My father in law loves his pen and writes with it exclusively, and he has to buy his refills in pairs because he blows through them so fast. This has also led to my previous threads about smooth writing gel rollerball or pressurized ballpoint refills that fit the Parker style that last longer than Parker brand gel rollerballs, which is what I'm using now. I haven't found a good solution there yet.
But I digress. I looked up some old posts about Baron caps coming undone and that led me to the idea of an o-ring, that would sort of "lock" down the nib section to the twist mechanism in the Sierra. It would have to be one small, thin o-ring, so I think a Home Depot trip is in my near future.
sbell111
Franklin, TN
bitshird
Yes, but the white Elmers glue is a bit harder to get it to let go, also the school paste is a little easier to clean off the threads next time around, My only complaint about the Sierras has been having 5 or 6 returned due to customers "unscrewups" and regardless it seems to leave a bad impression with the customer even when you show them how NOT to do it.
gwilki
Ottawa, ON, Canada.
I had two customers unscrew their's get it apart, then when they put the new refill in they pushed the transmission up into the body so far that it wouldn't thread onto the connector any more. I had to pull the transmission out with small needle nose pliers. Now, I CA the transmission into the barrel. To change the refill, the client simply retracts the refill and keeps turning. The transmission stays in the barrel and the whole assembly screws off the lower body.
GouletPens
Ashland, VA
In my (never) humble opinion, this is the proper way to change the refill on a Sierra. Thanks to Jim (jrc) for the video. http://www.youtube.com/watch?v=o9OSxFaVnuU
I agree this is an effective method, but honestly it's not realistic to have our customers use pliers for any purpose on their pen. I'm hoping we can come up with something that's really foolproof, that requires no tools (Mont Blanc doesn't tell their customers to use pliers to change their refills, why should we?).
GouletPens
Ashland, VA
Part of the reason I'm really concerned about this is that I'm expanding into wholesale/consignment selling where I won't necessarily have the ability to 'show' the customer anything. It won't be like a craft show where I can show them what I'm talking about. I really need a solution that falls in line with logic and simple pen use. I'm thinking o-ring is the way to go. Any experience with o-rings anyone?
bitshird
I agree, but how do you explain to the customer not to crush the brass threaded area? or grab the tranny near the top. For us it's not a problem, for a Doctor or Surgeon there again not really an expected problem, but there are others that don't have a delicate sense of touch.
Pleas don't think I'm taking an argumentative position I'm not, I'm just seeing what wisdom you could impart.
DCBluesman
Things that screw on and off are going to screw on...and off. Glue or loctite will hold the threads until you replace the refill, then you will need a fresh application. Would you rather have your customer hand- or even pliars-tighten the transmission (with help from a You Tube video) or would you rather they start messing with glue near the transmission. At some point, the customer has to learn something. Your other choice is to get away from twist pens.
GouletPens
Ashland, VA
There are plenty of other brands (Cross, Mont Blanc, Waterman, etc) that have twist pens, what do they do? I don't own any of these other brand name pens, but how do they make it work without glue or pliers?
DCBluesman
Brian - First, neither my clients nor I have problems with Sierras coming apart in normal daily use and I've sold a boatload of them. As for Montblanc and the others, I suspect they use threading that has a different profile which "locks" better...probably square threads. We do not have that option.
GouletPens
Ashland, VA
I've also sold a boatload of them but a couple my customers have complained. It's not how I give them the pen, but it's when they go to take out the refill (often right away, to see what it looks like) and they screw it back together themselves but don't twist it hard enough.
A potentially huge consignor for my pens had the untwisting thing happen to them and they don't want to carry the Sierra style anymore unless I can come up with a more foolproof solution than telling them "they need to tighten it more". The Sierra is a very popular style and more importantly is easy to make so I have to come up with a good solution, and fast!!
pentex
Granbury, Texas, USA.
One person on here uses a small amount of ca on the top part of the transmission and pushes it up into the blank. Then the only way to change the refill is to unscrew the top from the bottom. I tried this and it seems to work fine. You just cannot pull it apart, you have to unscrew it. Hope this makes sense.
Rudy Vey
South Plainfield, NJ, USA.
Alternative would be to stay away for the twist Sierras and make only clickers:eek:
Never had this problem, but I hand tighten the tranny as much as I can , and explain the whole changing procedure to my customers - never would tell them to use a pair of pliers, though!
bitshird
Or use the Elegant Beauty, the transmission can't come off, it's in the top of the pen, it's similar in style, a bit shorter and a wee bit smaller in diameter, I'm not referring to the Elegant Beauty Sierra but the one from Lau Lau woods or from Anthony at the Golden Nib, Plus they don't have junk plating's just, TI gold or black.
That is what I do, glue the finial to the upper end of the transmission when I press it on. Then, just twist the body to the stop after the refill retracts and twist a bit more to unscrew the transmission coupler from the nib. I started doing this when I realized that you couldn't really tighten the threads enough with the finial slipping on the transmission.
Exactly. When I had my first Sierra finial slip on the transmission, I assumed that it was a sloppy fit and should work like the Carbara/Atlas pens where the only way to get the refill out is to unscrew the nib from the body. So I glued the finial to the transmission during assembly. Works fine, none of this messing around with pulling the pen apart.
DCBluesman
Some of you are answering the wrong question. From the original post:
The problem is loose threads that let the top and bottom separate.
GouletPens
Ashland, VA
Lou, you're right. I think gluing the mechanism to the finial will help (allowing someone to really give it a good twist to lock in place), but the potential for the same problem is still there. I thought long and hard and chased around to several different stores tonight trying to find a good solution. I like the idea of some sort of o-ring to help keep it in place, but they're hard to find that small. I thought maybe a rubber band like you would have for braces might work, but apparently only orthodontists carry them. I'll check with them tomorrow. The other alternative would be an actual rubber o-ring, but even online I'm having a hard time finding one in the right dimensions. I'll update as I find them.....:bulgy-eyes:
GouletPens
Ashland, VA
I think YO YO Spin had a source for small washers. Check with him. I think maybe here. http://allorings.com/cgi-bin/Catalo...tx&hdr=Order+Buna-N+O-Rings&displayNumber=369
No way!! I actually came across this site in my own searching not but one hour ago.....I found the right size but I don't know if the o-ring will be too thick...I was looking at -011 which is 7.65±0.13mm internal diameter and 1.78±0.08mm thickness. I guess one way to find out is to go ahead and order them!
RichAldrich
Colorado Springs, CO
On O rings. I found a great selection of O rings at Gilroy's Hardware. They are on the web. 26 locations in Michigan and 1 in Peachtree City Ga. 5 miles from my house. Ace Hardware had a good selection as well.
Rich Aldrich
M
Mudder
Guest
I wrap a rubber band around the transmission to give me better grip and I tell all my customers to do the same. I guess that I sell to a different crowd because I've never had one returned for that reason.
GouletPens
Ashland, VA
Rich Aldrich
I just checked Gilroy's online and they only have bulk plumber's packs of orings. They don't have stores here in VA. I'll check Ace's though, as well as Advance Auto and Auto Zone, we'll see what happens.
GouletPens
Ashland, VA
I'm having a hard time visualizing what you're talking about here. Can you elaborate?
Rudy Vey
"I'm having a hard time visualizing what you're talking about here. Can you elaborate? __________________"
What Scott meant was that he wraps a rubber band around the transmission to get a better grip for tightening the transmission to the lower (nib end) of the Sierra pen. And that he sells his pen (like I) to a different crowd than you because we have no customer complaints that the pens come un-done - this btw has also never happened to my or my wife's personal Sierras.
GouletPens
Ashland, VA
Sure! Well, I couldn't find an o-ring small enough to work...I found one small enough to fit on the transmission, but the thickness of the actual o-ring was too thick and caused problems. I ended up doing a two-fold solution, though I'm still not very satisfied with it. I'm gluing the top of the transmission into the cap of the pen, which will allow you, when you twist the pen, to really ratchet it down to tighten it up. Also, I'm putting a thin bead of epoxy at the base of the threads on the transmission, to give some 'grab' when the transmission closes down to the nib section. It's not a great solution and it takes a bit of time, but it works for now. Anyone have any better ideas?!:neutral:
TomW
Allen, Texas
Brian,
I was actually out in the shop with my o ring assortment this morning, and came to the same conclusion. I was thinking about a ring cut from a sheet of silicone instead of an o ring, but then remembered they sell these to HELP you take a nova chuck loose from a lathe spindle.
I sense a perfectly sized lock washer would work, so I guess one could scratch some matching grooves between the nib and transmission, but that would be subject to lots of patience and luck.
Tom
