workinforwood
I am curious about the JR CSUSA tubes. Obviously, the JR Gent II tubes work the same in all the other CSUSA jr kits..jr statesman, jr retro, etc.
But then there is Berea Jr Kits. I see the tubes from CSUSA are identical to the Jr triton kit, although there is one exception...the pen tube is slightly shorter. So a JR Gent II tube can be used with a JR Triton Kit and the only modification you need is to remove the triton spring and replace it with a slightly longer one.
So what about the Jr Majestic? How do the PSI Jr tubes compare? Are they the same ID/OD ? Are the lengths different than the Jr Gent II ? I have never made a Jr Majestic. The only comparison I know between the two kits is that replacement Jr Majestic tubes cost 3 times more money!
