Jr. Statesman II bit size
sparhawk
Rosinton, Alabama, USA.
For those of you who make these kits, do you use the 12.5 mm and 10.5 mm drill bits or the 12.5mm and the 27/64ths. Or is there another bit in place of the 12.5.
Daniel
Reno, NV, USA.
If these are the same size as the Jr. Gent. I like the fit of the tube with the 12.5mm bit but the 10.5 was to loose for my liking.
Texatdurango
Show Low, Arizona
Thanks for the quick replies guys. I have a couple of kits but not the metric bits. Was wondering if something else would work.
The 12.5mm is pretty much the only size I like after trying all the closeby sizes.
Get a piece of scrap wood or acrylic and drill a "Z" size hole and see how you like it for the lower barrel. That's what I use and would be one less metric bit to buy assuming of course that you have a letter drill set. :wink:
NewLondon88
Local Chapter Leader
Claremont NH
I use the Z bit and a 1/2" for the top, especially if I'm doing Tru-Stone.
Those blanks don't like to be expanded at all and this seems to have helped.
Daniel
Reno, NV, USA.
1/2" is only 8/1000" larger than the 12.5mm. I would not expect it to be a problem. a looser fit yes but not so much that it would not work.
10.5mm and Z are the same size at 0.413"
NewLondon88
Claremont NH
Yep.. I should have mentioned that. I didn't want to go out and get a set
of metric drill bits just to get one or two, and I already had a set of Enco
A-Z bits in the shop, so that's when I reach for the Z.
I might have to get the metrics anyway..
