Jr Gent Kit
glenspens
Jonesborough,Tn. USA 37659
just made 3 from them w/no problem ...which way did you put the spring in, small or big end to refill.... just using a old tape here at work looks like the top tube is 1 3/4 the lower tube 2 1/16 that from a pen i have with me
timberbits
Sydney - NSW - Australia
Hi Pat
As I have responded in the email you sent me yesterday.
The barrel is not too long. You need to put the spring behind the refill to push the refill out of the nib. If you put the spring on the nib side of the refill, it will push the refill back into the pen, hence why the refill is not sticking out of the barrel.
Regarding the bushings. It looks like you have some glue and contamination on the inside of the barrel. You need to clean out the inside of the barrel otherwise the bushing will not fit into the large tube.
Let me know if you have any further questions or need more information.
Regards
David
