Jr Gent I & Jr Jent II question
Joemac8
Chicago, Illinois USA
Are these kits the same? I ordered some coffee bean blanks (or what I thought were blanks) What I received were coffee bean blanks drilled with tubes for the Jr Gent. I tried looking up the Jr Gent and all I found were the Jr Gent II. Are they the same?
hunter-27
Passed Away Aug 14, 2013
Chadron, Ne, USA.
No they are not the same. I would ask the vendor which kit they were designed for, they will not be interchangeable with the VI and VII.
Whaler
Sequim, WA, USA.
Possibly a labeling error. The Jr Gent uses much larger tubes than the Jr Gent 2 so it's easy to check if you have a set of bushings or just measure the hole. The Jr Gent 2 uses 10.5mm and 12.5mm drill bits.
Lenny
Searsport, Maine
FWIW...
The Jr.Gent II is bigger, using drill bits 12.5 and 10.5
where the Apprentice Jr. Gentlemen uses 25/64 and 15/32 drill bits.
I am not sure if the original Jr. Gent I was the same as what is now called (by CSUSA) the Apprentice Jr. Gentleman but I often refer to it as the Jr. Gent I (probably incorrectly)
A similar set of components to the ApprenticeJr. Gent is available from many different suppliers.
Lenny
Searsport, Maine
Dick, I think you mean the original Gent pen, not the Jr. of either version..??
RDH79
Rimersburg, Pa, USA.
Sounds like you didnt read the info very close also. The coffee bean blanks that you got are for the Jr Gent 1. I got some of them also thinking that they were the JR II. Luckily I had a few of the I's.
its_virgil
Wichita Falls, TX, USA.
The jr gent I uses the same tubes as the baron or at least the original jr gvent I did. Check the drill sizes for what you have against those for the baron (navigator or tycoon.)
Do a good turn daily.
Don
Sent from my Samsung Epic using Forum runner
PenMan1
Eatonton, Georgia
Don
This is correct. I just checked the Jr Gent I that I have in stock it uses the same tooling, drill bits and tubes as Baron, Sedona, Navigator and Rhinehart in the Berea line. Those tubes ARE JUST SMALLER THAN THE JR GENT II
Whaler
Sequim, WA, USA.
I was using the info in Daniels chart in the library. After going back and looking at it again there seems to be some errors.
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Yep
FWIW...
Drill sizes and bushings for the original Jr Gent are the same as the Apprentice Jr Gent and not the same as any version of the Jr Gent II.
