jmbaker79
Hey guys, I have been working with these for awhile and never had too much trouble out of them but after cracking a few materials during assembly iv have a question or two... First off the issue is getting the couplers in the lower barrel requires great effort. They are so tight, haven't measured them but can't imagine it has much clearance at all. Tighter than any kit ive ever worked with. From multiple vendors as well, so that's unrelated. The caps are never a problem. I resorted to using the lathe as a assembly press a while back and it works great for depth and precision...But... Still crack one very so often, only the good ones too! So... Possible to lubricate them somehow, or any other tips or tricks to aid in a smoother assembly. I've gone as far as sanding the couplers but that doesn't seem to help, if anything it just makes it tight, AND rough. No glue in the tubes either so we an skip that...Thanks in advance
