Jr Gent bushings
ldubia
Boulder Creek, CA
Do te original Jr Gent's, not the 2's, use a different bushing than the upgraded 2's? I have a pile of them and they don't match the bushings for the JG2.
Any ideas?
ed4copies
Local Chapter Manager
Racine, WI, USA.
The jr one version was very similar to the baron---or the Navigator from Wood craft---but someone else will probably have the chinese kits and can tell you what works.
its_virgil
Wichita Falls, TX, USA.
Baron and the jr gent 1 use the same tubes. The baron's lower barrel (not the cap) is straight so those two bushings are the same diameter. But on the JR v1 the lower barrel is not straight and the two bushings are not the same diameter. Use baron, navigator, or tycoon bushings and measure the pen parts with calipers and size the blank to match. Or, get jr gent 2 bushings from smitty37. You can find him in the business classifieds.
Do a good turn daily!
Don
