I've done dozens of these, and never had that happen, nor have I seen that particular failure happen to anyone else. I've buggered up a few centerbands, usually when trying to take that top retaining ring off so I can replace the gold one with a custom band. I wonder how you are pressing these assemblies into the tube. Is the bottom of the band on a flat surface, and is the pressure straight down? You have the black threaded insert installed in the centerband?
Is the fracture happening before the band is fully seated, or is it breaking after you have it all the way in and are trying to close up that last tiny little gap with some extra pressure? If the latter, you may avoid it by just putting a little reverse bevel onto that end of the tube, so that the outside edge of the blank will touch the flat of the centerband before the inner edge of the tube does.
Of course, you may have just gotten a couple of parts from a bad run from supplier x in China. I would presume that anybody that you can get that kit from will stand behind it and replace them for you. That particular failure is almost certainly due to a manufacturing defect in the centerband, not something you did to a centerband that is up to the same specs as 99.99% of the rest of them.
