Jr Bushings
StanBrown
Waller,Texas
Can anyone tell me if the bushings for the Jr. Harold are the same bushings that are used for the Jr. Gent?
For that matter, do all of the "Jr" series use the same bushings?
ed4copies
Local Chapter Manager
Racine, WI, USA.
yes, and no.
The jr harold does use the jr gent II series bushings.
The jr. emperor and jr abraham (and possibly others) use a different bushing.
You can determine what bushings you need by simply measuring the pieces (components) you are going to mate with. The body of the jr. emperor is straight, both ends are the same diameter. The Jr. GentII slopes, with the nib end being larger than the finial end.
All the Juniors have a cap that is straight, same diameter on each end.
Hope that helps,
Ed
Also answered your question on our website, found lots of others I will have to answer tonight--haven't looked at that in a couple weeks--Sorry!!
Woodchipper
Cleveland, TN
Thanks, Ed. I have also found to look at the extensive chart for bushings, tubes, etc. on the IAP website. It has proved to be invaluable.
