PTsideshow
Ok just got the hole in the basement large enough to set up the lathe, and the other toys. Figure I would use my pen pro and practice on some solid surface material. Well the pen pro worked a treat and even though I had the blanks 1"x3/4" No drilling just turning used a center point drill and then turned between centers.
After using the abranet abrasives from 150 through 600. Great stuff by the way. I switched to the micro mesh to 1500 then since is just practice I used some good old paste wax for a friction polish and buff.
Do the join lines show when the blank is turned down to pen size?
If they show is it from not enough clamps?
Or not enough adhesive on the blank halves or is it the use of activator on one side?
:clown:
:clown:
