Jet mini lathe dust shrouds???
rjwolfe3
Mansfield, Ohio, USA.
PSI is where I got mine but I think quite a few places carry them. Mine is magnetic and has a shield that flips up with a 4" opening for the hose.
Crayman
Hopkinton NH
Greg, If you get this, one thing I did was add a bottom panel extension made from some scrap plexiglass and velco. This stopped most of the larger piece from dropping down on the motor. When I don't need it for bowls or want it longer just adjust or remove it the bottom panel
randyrls
Harrisburg, PA 17112
I've seen a pic of a Oneway or Powermatic lathe with a rod on the back side attached to a hose end. The rod is behind and parallel to the lathe axis. Just put a 4" DC hose end coupler with a small attachment to connect the rod to the hose end. Easily adjusted and simple.
