woodmarc
While i'm laid up, I thought I would give the lathe a bit of a cleaning and a lube. I noticed, when I brought the tail stock up to the head stock to so that I could clean the bed rails, that the tail stock had a lot of play. I would say as much as a 1/16" of play on either side of the headstock. is this normal? and could this be the culprit behind the intermittant problem that I am having with out of round pens?
I will have to investigate this further. but does any one have a suggetion on how to reduce ir remove this play?
My lathe is jet mini vs. It's less than a year old. should i contact jet?
TIA
TIA
