If you're in a rush, go to Home depot. They carry a toggle switch from Gardner Bender that says it's an SPST Toggle Switch, marked GSW-11 in the upper right hand corner, that can be used with a simple modification. As Andy pointed out, these are screw terminal connections on this toggle switch, but rather than cut the blade connectors off of the jet wiring, I took the screws out of the toggle switch connector blades, and used a pair of wire dykes to trim the broader "ears" of the screw terminal connectors so the blade connectors on the jet wiring would work. Also had to use my bench vise to "flatten" back down the portion of the screw terminal that had been drilled and then tapped to fit the screws. About 2 minutes to do these simple mods, and back in business. After hearing this was such a common problem, went ahead and bought a second switch to keep on hand, which is still in the original packaging. On the back, below the bar code, the product code shows to be 32076 89077. Package indicates this is a 10 A 277 V AC/20 A 125 V AC/ 3/4 HP 125-250 V AC toggle switch. I want to say it was $3 or $4 bucks each. Good luck!
