redfishsc
I am considering buying a jaw chuck that will be used mostly for drilling blanks for larger pens (Emperor, Gents, etc...). Since I am moving and will be losing access to drill press (and I like the accuracy of lathe drilling) this is the way I need to go.
However, since this is a non-typical way of using a lathe chuck.
Does anyone here use the PSI Barracuda (1) to do this? Does it allow "through" drilling? Since it comes with several jaws, including "pin" jaws and some good jaws for bowl turning (which I also do).
BTW, the Beall collet chuck can drill things 3/4 in diameter with the right collet. Given the dead-nuts accuracy of this item, will 3/4 be a large enough blank for an Emperor or Gent?
