Itsy, Bitsy...
ThomJ
Fairlee, VT
teenie weenie yellow polka dot bikini!!!!!!!!!
I need to make a red blank with yellow polka dots in it.
Any hints, suggestions, This going on an elegant beauty sierra
Old Lar
Sturgis, SD
This is what I tried. Drilled holes and filled with poly clay. Works for wood, may not work on a resin blank. This was just a trial, wish I would have picked an unspalted blank,
leestoresund
Marietta, GA
Just thoughts.
Get a stabilized redwood blank (or a red dyed maple) from AS and an Osage orange blank.
Use a plug cutter on the Osage and fill same size holes drilled in the redwood blank with the round pieces from the Osage.
Lee
Jgrden
hOUSTON, Texas
Hmmmm. I threw a .30-06 bullet away today that had a cavity in it. I threw it away because I had cracked the resin inlay. It needs to be pulled out of the trash and filled with clay. What a novel idea. Thank you.
Glad you didn't charge for it.
