Infinity76
So I'm new to pen turning and having issues drilling the blank.
I'm using the correct size drill bit as stated in the instructions and I also checked the size of the brass tube.
However, I have used a drill press and drilled another one on the lathe. But I'm finding that the tube will go in half way and then becomes stuck, it goes in the other way ok, but then gets half way and gets stuck again.
I used the drill bit a number of times, but nothing is making the brass tubing go all the way through.
Any ideas?
Sent from my SM-G955F using Tapatalk
Any ideas?
