I recently attempted to make a pen with brass inlays. What I did was to cut the blank at 45 degrees and incerted a piece of .005 brass sheeting and glued the pieces back together. I Then cut the blank a 45 degrees the opposite direction and inserted the piece of brass. I then rotated the blank 90 degrees and repeated teh process. The goal was to have 4 brass circles with various angles. This part was ok. the problem was that the circles did not meet evenly causing a break (slight offset) in the lines. I would appreciate any sugggestions to resolve the problem. thank you, Tom
