Gary Max
Had several folks ask ----so made some time today.
This is one of the Eagles that I have for sale over on the MVV forum.
I will get the pics loaded and come back and try to add enough info to get you headed the right direction.
I figure out where I want the inlay to sit---mark the top and bottom--
Then I drill holes to match the lenght of the opening I want. Then I use a router or a Dermal tool to open the hole to the size I need for the inlay
After I get the hole the right size I build the blank---installing the painted tube with Epoxy. I add a little extra to the hole after the tube is installed to make sure the inlay get a good seat.
I mount the whole pen on the lathe and fill the hole full of Epoxy and let her dry. PR would do a good job but I am out right now and Epoxy works.
This is what it looks like on the lathe. I will get it done in the morning.
Hope this helps.
Oh the blank---Yup it's Dalberg Stevensoni from Nolan.
Kit is a Jr from CSUSA
Hope this helps.
