Inlay Rollerball
bjbear76
Louisville, KY 40299
Has anyone tried (and had success) using an inlay blank to make a rollerball?
I have a request to make a sierra and a rollerball with the same inlay kit.
The inlay blanks are pre-drilled 27/64; the rollerball sections are 10.5 and 12.5mm. The 10.5mm tube is too loose inside the blank.
Any options?
magpens
Canada
Can you use a rollerball kit that is based on a 3/8" tube ? Don't know if there is one.
I have used an inlay blank on a click Vertex (PSI) which has a 3/8" tube.
I inserted and glued the 27/64" tube inside the inlay blank. Then I inserted a 10 mm tube inside the 27/64" tube. After a bit of careful sanding (on lathe) to reduce its OD, the 3/8" tube fits inside the 10 mm tube.
Some length adjustment was necessary to get the inlay blank up to the required length of the Vertex requirement (I used 2 equal length accent rings, one on each end of the inlay blank).
The length of the intermediate 10 mm tube is not critical. I actually used 2 short pieces of 10 mm tube cannibalized from a Cigar kit.
Good luck. I wish you success.
dthayer
Prescott, AZ
The Rollester and 50 Cal Cartridge Flip Pen kits from PSI both use a 3/8" tube and are rollerballs. Not sure about other kits from other vendors but this might be a start.
(Not sure if the flip pen would be what your client would want but it is a fun kit -- I just finished one!)
Hope this helps...
