Ink Pumps won't fit - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 10-01-2016, 09:51 AM   #1 (permalink)
BURLMAN's Avatar
Photos: 10
Default Ink Pumps won't fit
Anyone else having problems with ink pumps not fitting on Optimus, Raven, or Eagle fountain pens?
BURLMAN is online now   Reply With Quote Top
Old 10-02-2016, 02:24 PM   #2 (permalink)
Photos: 0
Default
I've had similar issues with Schmidt converters not fitting into Junior Anthonys. The Schmidt converter has a metal band on it that will not pass through the threads that the section screws in to. I've wound up having to use converters that do not have the metal band.
dtswebb is offline   Reply With Quote Top
Old 10-02-2016, 04:24 PM   #3 (permalink)
Photos: 0
Default
I have had the same issues with some kits also. I wanted to keep the convertor with the metal band due to my feeling that it looked to be of better quality. I ended up sanding and then polishing the metal band to make it fit.
taz442 is offline   Reply With Quote Top
Advertisement
Old 10-02-2016, 05:12 PM   #4 (permalink)
edstreet's Avatar
Photos: 2
Default
This is a very well known issue and a very old OLD problem. The problem lies in the feed where it connects to the converter (ink pump). One brand will while another may not. It does vary according to who made the nib/feed as well so take note which one will and will not.
__________________
Anyone can COPY, it takes a *TRUE ARTIST* to CREATE
-- In times of universal deceit, telling the truth becomes a revolutionary act.
Design your own Polymer Clay Pen Blanks by Toni, Detailed 'CA' Article
edstreet is offline   Reply With Quote Top
Old 10-02-2016, 07:21 PM   #5 (permalink)
Photos: 0
Default
I think we are actually talking about two different issues. One where the convertor does not fit onto the feed. The other where the band in the middle of the convertor does not pass the threads where the feed screws into.
Personally, I have not had a convertor not fit into a feed but will keep an eye on that as a possible issue. As stated in post #3, for the band in the middle of the convertor not passing past the feed threads, sanding & polishing the band will allow the convertor to pass.
Old 10-02-2016, 07:23 PM   #6 (permalink)
Photos: 0
Default
Just a thought, you may be able to sand & polish the metal band that fits into the feed also. Depending on how much material needs to be removed.
Old 10-02-2016, 07:57 PM   #7 (permalink)
Photos: 0
Default
Sounds like sanding/polishing the band on the converter is not the ultimate solution. What does the customer do when they need a new converter?
__________________
Rick Beckham
Belton, TX
beck3906 is offline   Reply With Quote Top
Old 10-03-2016, 10:47 AM   #8 (permalink)
BURLMAN's Avatar
Photos: 10
Default
Attached is a picture of several feeds of fountain pens I have completed. On the left are four identical feeds from two Optimus Desires, a Raven and an Eagle. On the left are two from a Jr. Gent II and a Magnetic Vertex. Notice the extended nipples on the two on the right. The threading on the two styles is also different, making them non-interchangable.
I am somewhat mystified by this because I include a converter with every FP I sell, and I have sold several Optimus, Raven, and Eagle FPs in the past, with this never having been an issue. It's an issue because I lost a sale this past Saturday at the Knoxville market because the customer wanted a converter to go with the Optimus he wanted to buy, but I couldn't get one to fit.
I am going to direct Constant to this thread so he can look into it. In the meantime does anyone out there know if there are feeds available that will accept a converter and are compatible with Optimus, Raven and Eagle. Alternatively, are there different brand converters out there that are compatible with Optimus, etc. Many thanks to all for your inputs.
John
Old 10-04-2016, 11:12 AM   #9 (permalink)
Photos: 0
Default Require standarization
I have had the same problems.The solution is for pen kit suppliers to have a common standard. Other industries have a common acceptable standard.
__________________
Stephen
Stephen is offline   Reply With Quote Top
Old 10-04-2016, 12:24 PM   #10 (permalink)
BURLMAN's Avatar
Photos: 10
Default
I have never been acclaimed as the sharpest knife in the drawer or fastest swimmer in the pool. This thread I initiated is a good indicator why. I talked to Constant a couple of hours ago (fantastic gentleman by the way), and as our conversation progressed, my dim bulb began to glow more brightly. I was trying to fit a Schaefer converter into a Schmidt nib feed. Duh!! Hopefully my embarrassment will be of value to other members here. BTW Schmidt converters are on my shopping list.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
