Info on air compressors...HELP.
jenamison
Tallahassee, Florida, USA.
I read the article posted the other day about making your own stablized blanks and was wondering if anyone knows if a air compressor will pull a vaccum? I have a regular upright Husky electric compressor. Any help welcome.
--Sincerely
Mike Amison
loglugger
Lebanon, Oregon, USA.
Mike, I am useing a old cast iron one piston oil bath built in about 1948. 1/2 HP. no tank. Have used it for about a year. 200 or more pens. I don't know how safe with the ploy fumes going throu it but it hasn't blow the shop up yet. it pulls 22 " vacum doing a very good job.
tipusnr
Reynoldsburg, OH, USA.
Harbor Freight sells a vacuum pump that works off of a compressoer. Some of the guys here have it (not me) and should come by for comment soon.
ctEaglesc
Passed Away Jul 4, 2008
Camden, S.C., USA.
Check out this thread from the other day:
http://www.penturners.org/forum/topic.asp?TOPIC_ID=6174&SearchTerms=HF
At the bottom of the first page is a link to Joe's workshop.It has plans for two vacuum pump.
One uses a compressor to pull a vacuum through a venturi.
The site sells a similar venturi as the one from HF.
I use a very crude set up without the automatic switching.
Though this will put a stabilizing mixture into blanks it cannot be compared to the results you will get from pressurized stabilization.
I have no idea what percent of acetone plexi I use(Volatiles/solids.Assume I use a 50% mixture,once the acetone evaporates only half of the solution is left in the material(plexi, or solids)
This is no where what the end product of a pressurized process will yield.
It works for what I need, but I do know it's limitations.
ctEaglesc
Camden, S.C., USA.
Originally posted by jenamison
<br />Oh ok now I understand...I need another device attached to the air compressor. Thanks for the responses.
Mike
That depends.
If you look at the plans in the site I linked to, there are two designs.
One uses a simlar valve sold at Harbor freight for $10.00 on sale.
The other is based on a compressor from a refigerator.
