mbroberg
I finished (so I thought) a Jr. Gent last night but when I assembled it I found that I had over turned the top end of a barrel (opposite the nib) just enough to be noticeable. I'm going to try to build it up with CA, as I have read about here in the forums. I stink at doing CA finishes, and I have never had to increase the diameter of a pen with CA. It is a polyresin blank. I'm planning to hit it with thick CA to slightly over sized, allowing it to cure for about 1/2 hour then sand it down to the correct size. I suspect it will not take much. So.....I'm seeking the advice of the experts. Does anyone have any tips of tricks to offer before I attempt this tonight?
Thanks,
Mike
Thanks,
Mike
