Ken Massingale
Finally did it!
I'm making some PSI Longwoods, which have a center bushing with a tenon on one end, that is inserted into a blank end that has no tube in it, on that end.
I thought I saw a tiny crack on the other end of the blank at the end of turning so I applied some thin CA to seal it. Reckon some of the CA found it's way down to the other end and I can't get the *&^%$ bushing out so I can asemble the pen. I've pulled twisted and cussed a wee bit, dabbed some acetone into the sick end hoping to dissolve the CA bond, but no luck.
I'm ready to break the blank off the bushing, unless there's help to be had here.
TIA,
ken
TIA,
ken
