Scooley01
I originally was using CA to glue my tubes, and it was working great...as long as the hole I drill is steady and the bit/jig didn't wiggle at all. If it wiggled at all during drilling (ie the hole is slightly bigger than the bit is supposed to drill) then when I go to mill the ends with the barrel trimmer, the tube has a tendency to stick to come out of the blank with the trimmer. It's only happened a handful of times, and I just clean the tube off and use two-part epoxy for the second gluing and I haven't had issues beyond that.
Well today it happened again...and this time, the tube glued itself to the barrel trimmer. I had to soak the trimmer/brass tube in acetone and peel off (by tearing!) the brass piece by piece...and unfortunately I don't have any extra tubes for that kit, so now the whole order is delayed because I'm too impatient to use epoxy.
*sigh* I just need to get over the 2-3 hours of waiting involved with epoxy and just glue everything a day ahead of time or something.
Another revelation today: The tiny table saw I bought from Harbor Freight that was really a pain in the butt to use can't even hold a candle to how awesome a back saw and a miter box is. Seriously, it's hardly any extra effort to saw it by hand, and the results are infinitely better!
